gary wrote:Sorry Harry I don't understand the difference between
nbtvcrystal.wav which is good
and nbtvencoderl.wav which is bad
Can you point out the different circuitry - I was under the understanding that whatever speed control you were using you were using the encoder. If you are not using it with the crystal circuitry what is controlling the speed of the motor?
You now have me absolutely and totally confused.
OH i was thinking the file was bad ...every thing plays ok
I get ya ..Gary same circuit just using either the mechanical sync 400hz pulse or crystal clock 400hz to feed via the mono to the video sync mixer so i can view either really just via that switch ! nothing apart from that switch was needed .
OK ...i have a switch ....3 connections center is to your 555 filter monostabe so when i switch the 400hz crystal position it feeds to your 555 mono it to the sync of the video sync mixer ....switch to the other position which is connected to the output of the Lm311 encoder circuit i get mechanical sync ....
The motor control is the same encoder circuit crystal circuit to the 4046 pll so all i am doing swapping the mechanical sync for the crystal clock via that switch to the video sync mixer in other words .
My idea was if the motor is synced to the crystal clock why use the mechanical sync where you see mistakes as the lines not matching up ...only problem i think is more framing ? as theres no missing sync pulse with the crystal clock ...what it looks like i am happy with rolling or not...i am sure others have used the idea ,i tried it on the fly spot in 2012 but i fed the clock right to the sync mixer and the pulse was to wide getting half a picture as i recall and i did notice drift back then as well...its in fact the same crystal come to think of it !
I will post up a schematic of the changes i have made since my first posting up might take me a few days need my notepad
