Steve Anderson wrote:If Fig.7 applies to the 6199 and it's the type you're using you may as well use their suggested circuit. The gain varies with the supply voltage greatly. A change from 900 to 1000V can easily double the gain - it does vary on the type of tube and each example too.
The way you've wired the tube base is fine, it's the way most do it.
'Reasonably close' for the pre-amp is how I'd put it, don't fret over a few inches, but remember this is a high impedance arrangement so you need to be careful with hum and interference pick-up.
Klaas Robers wrote:Harry, no need for a UV LED. The PMT is also sensitive to green light and even to red light, it is only LESS sensitive. And as there is no problem at all with the sensitivity of PMTs, you can use any colour. You have to squeeze the current any way to very low values.
Steve Anderson wrote:Imagine sitting a totally darkened room for an hour, and I mean totally darkened. You see the slightest glimmer of light - just. That's far too much for a PMT. I couldn't see the blue light the 931As were responding to, even after my eyes were dark-adapted.
If you have a lot of light (as far as a PMT is concerned) keep the volts at the very low end. Don't exceed the maximum tube current - it's so easy to do!
Steve Anderson wrote:Harry, inverters simply by the way they work are generally noisy. I wouldn't even consider one for a PMT supply. There are probably exceptions but they're unlikely to be found in any domestic or office piece of gear.
Do it yourself, where you have control and if it isn't still good enough consider and examine why. When it's designed in some far-off land to be the cheapest possible - what can you expect? The only criteria in the far-east is it must be cheaper. Bugger quality, performance or reliability. It works in the shop, it doesn't when you get it home. Been there many a time.
[/quote]If it says, "Made in China" as a finished product, I don't buy it and place it back on the shelf. Something like semiconductors supervised by Philips, Motorola, Microchip, etc, that's OK. You're fairly sure that the product meets the required standards. But something made by the, "Golden Dragon Electronics Corp.", think again.
If there is such a company (most likely) I apologise in advance. I have never bought one of your products for the reasons above.
