Re: Photomultiplier Tubes camera build
Posted: Mon Dec 26, 2016 11:41 am
gary wrote:
A Merry Christmas to you and yours Harry!
(BTW just so we are on the same page - when I was talking about 44.1kHz I was referring to this file: nosync24thvideotopin2.wav - that was when you injected an NBTV test wave into your system which I thought was a very good idea but it is the original of that file (the one you injected) that needs to be made 48kHz - not the recording.)
Arrrr Boxing day life is easier for an NBTVer today ~
Yes what i did and i will double check i got the NBTV video file with all those test cards looked at it in my audio recording program ....it showed me it was at 44khz or so so i converted it to 48khz ...then pl;ayed the file with vlc player and injected it to pin 2 of the first ic of the video sync mixer circuit ......output from camera video output recorded to the second computer it records or saves it at 48khz...is that ok as the recording has to be saved at this or lower or higher khz rate ..i was thinking 48khz seems ok.
Today i will double check all this as i had 2 files with 2 different results so made a mistake ...i will post up the result being a careful this time and see what was right .
