Steve Anderson wrote:Check all those voltages and make sure they are there, from the +/-8V, +5V, +14V/-13.5V and the +120V, +220V. If they are present you can be sure it's either the inverter has failed or there's some sort of short/failure on its output.
It doesn't show up in the schematic and i just noticed it but there was a blown or open fuse on the circuit board at around the + of the 47uf cap that deals with the +211 voltage now i took the below readings after i replaced it so really need to check again with and with out as readings seem different to what i checked the other day.
Ok i had a little time this after after a mower repair this is more enjoyable to work on it ,finding all the voltages on the main power supply board is a bit tricky all the part codes are on the other side i don't want to pull every thing to bits ,with my glasses on and a light viewing at strange angles i can make out where most of it is , can see where all the Voltage regulators diodes are least its easy to test the solder side of the board .
Now what i found so far on the High voltage side
+120 is showing up as +117 volts
+220 is +211
I checked again the voltages at the inverter the plug i mentioned i am now getting
+12.8
-13.4
+117
I was hoping the fuse was the problem plugged the crt back in and still diddly squat
checked for any thing out of the inverter and nothing mmm
As I mentioned, trace back and find out what the heck that additional transformer is doing. That will probably give you a big clue as to other potential problems. Do not give up at this stage, it is worth the effort.
Its a mystery yes i must find out, i do know its putting out 9.6 volts ac to that little circuit board .
It looks like the instrument has suffered a blow or been dropped at some time in the past due to the bending/buckling of PCB supports, and the mention of your own observations of bent CRT retention screws. However, CRTs are quite rugged and there's every likelihood that this one has survived intact.
OH yes its got a big ding in the back around the plugs ,i am lucky that CRT is still lighting up had rubber holding it in place with the brackets so that might of saved it .
This is worth pursuing.
With out the CRT i would of given up but i want to get it going knowing its ok .
I don't mind this thread diverging for a while as the technology is all related. If the CRT has a rectangular face without an internal graticule - absolutely ideal for NBTV even if not for SSTV - that depends on the phosphor, most likely P1-like.
IT does have that internal graticule a pain but i can live with it
It's also quite a low-voltage CRT for its size and the rectangular face...count your blessings...
Thanks Steve ,i didn't want to take over your subject with this little side project ,if it gets going it will be used in projects for sure ,i'll swap over on the next post to its own ,i have a feeling this is going to be a tricky one .
