by Steve Anderson » Fri May 08, 2015 6:05 pm
Valves/tubes on PCBs were very popular in 60s TVs in areas where transistors hadn't quite taken over, primarily in the area of the line output/EHT supply stage. The bases were very similar to the usual ones, but had pins much like an IC instead of solder buckets or eyelets. (Photos below).
I have put valve/tube bases on stripboard before, the example below was for a NBTV CRT display I made some years ago. I admit I haven't seen anyone else do this but I'm sure someone has. The holes aren't difficult, drill a 6mm hole then using a hand-reamer gradually, carefully, open them up to 22mm (for this type of socket). Thankfully this is cheap SRPB board and not fibreglass.
Any transformer should be treated with reverence as it has raw 220V AC on its input side (unless it's something like a low-level audio transformer). On the secondary, it would have to be really puny not to be able to kill you, it only takes 30 mA across the chest and you're toast. So anything with a secondary voltage above 50V should be treated with respect. In theory the 70V 16Hz ringing voltage on an ordinary phone-line could kill you but most just feel a tingle and let go.
The transformer below is the 500V transformer for the -700V supply for this CRT - yes, it could well kill you.
But a bigger danger is the charge stored in the supply DC capacitors, even if the transformer is puny, once rectified and these capacitors reach 700V it's lethal - it's also DC.
But for decades before semiconductors we all got used to working with high voltages. One rule is when the equipment is switch on work with one hand behind your back or in your pocket, this lessens the chance of current across the chest, but it only lessens it.
Even when switched off CHECK the supplies have died down to zero, a capacitor in good condition can hold a lethal charge for days. It is good practice to put a 'bleeder' resistor across the capacitor to fully discharge them - but still CHECK, the resistor may have gone open circuit.
I don't want to put anyone off working with valves, you just have to be sensible about it.
- Attachments
- PCB Tubes 2.jpg (71.28 KiB) Viewed 12850 times
- 500V Tx 1.jpg (45.03 KiB) Viewed 12850 times
- 9-pin PCB Socket.jpg (19.03 KiB) Viewed 12849 times
- PCB Tubes 3.jpg (62.39 KiB) Viewed 12847 times
