Steve Anderson wrote:As with any test you need to think of your reference. When I said there's no overshoot is that something to do with the modulator used? So to eliminate any doubt is the sketch below viable? This will generate two tones settable anywhere between 1200 and 2300Hz (as a minimum) modulated by a square-wave at a lower frequency. No filters, no A-D or D-A and all the harmonics you could wish for.
In my modulator there is a filter, I want to eliminate any influence it may have on the results I'm obtaining.
It is a chicken and egg situation.
Harry Dalek wrote:Hi Steve if i am right you are using this 2 tone PLL modulator to test your demodulator to see if it is filtering locking onto the correct frequencies ? I have to ask why not just a frequency generator or test wav's ?
Steve Anderson wrote:Harry, there's no 'locking' involved, no PLLs anywhere, including in the demodulator. I'm just considering using the VCO sections only. I'm simply thinking of using them as a source of unfiltered modulation. There are two major sections to any 4046, the VCO and the phase detectors. Both are totally separate and could be used independently - just like two op-amps in a single package. It's only when you connect certain pins together that it becomes a PLL.
Here, all I need is an oscillator whose frequency is controlled by a voltage, nothing else.
Frequency generator, i.e. tones, done already, that's how the charts above were generated.
Test waveforms or signals. Where do they come from? Who made them? How reliable are they? Even those I made myself I don't trust until proven otherwise. Though the simple tones I uploaded some weeks back I'm happy with. It's rather hard to get them wrong in Audacity.
Anyway, it's a thought and I'll see what the results are. "if you don't ask, you won't get." "If you don't try you'll never win".
Klaas Robers wrote:Steve, for the SSTV FM-modulator I also used no low pass filtering in the video. So your "switched diagram" applies.
Steve Anderson wrote:Let's see how things pan out over the next few days...
Harry Dalek wrote:I gather the circuit your improved demodulator and sync detector are for cases of SSTV SSB reception cases weak signal detection ? a narrow sync bandwidth 300hz or a touch over ...
