Steve Anderson wrote:If you have any SSTV audio files in this system please upload them here. Wave files at any sample rate preferred but others OK. If they are at high sample rates they may be re-sampled/down-converted and changed to mono, then added.
Not only those that are perfect, but those off-air, complete with noise, interference and even tape recorder irregularities.
Remember the maximum single file upload to this board is 20MB and the maximum number of attachments per post is 50. (I know, wishful thinking).
Harry Dalek wrote:...i had one cassette tape but but still lost so far since my move in 2000...
Steve Anderson wrote:Harry Dalek wrote:...i had one cassette tape but but still lost so far since my move in 2000...
I think after 17 years we can give up on that! These things happen. Often I think, "Now where did I put such-and-such?" I search high and low and after a while I give up and presume it got tossed out or lost somehow. Whatever, you end up wasting a lot of time.
I'm looking for old(er) material to test the NBTV/SSTV-625 up-converter. I can generate 'perfect' SSTV audio files, I guess I could add in some white noise suitably filtered. But there's nothing quite like a real off-air recording to put this thing through its paces.
Steve Anderson wrote:An good idea Harry. Multipath reflections - use a bathroom. Other noises as QRM (interference)...use your imagination! Even dogs barking, passing cars and motorcycles...depends on your location to a large extent. Even a TV or radio playing in the background. Worth a try. An AM radio tuned away from a station to pick up static, and here at this time of year, thunderstorms...trouble is I don't have an AM radio!
Steve Anderson wrote:Quite a good result Harry, or should that be a bad result? Whichever, it's the sort of thing I'm looking for even if it's not quite genuine. Certainly worth following up on.
Klaas Robers wrote:It stores the digitized base band video signal in the EPROM, 128 x 128 pixels, reconstructs the video signal and that is FM modulated.
Return to Audio files for Cop McDonald's SSTV system.
