Last time i looked into what this monitor could do i really didn't touch on the framing side of the circuit as it tended to sync but a few years in a box testing it again on any thing other than 32 line i found this wasn't repeating the old results ,the main problem here seemed to be R622 ageing perhaps the resistors value has changed a touch or more likely capacitor C622 any case placing a 500k pot in parallel to over the R622 resistance did the trick .
Also replaced C721 with a 3 position switch now switching in C721 68NF 23NF 10NF caps and R704 18k a 25k pot over this resistor helps adjust video height
Framing as is unchanged here at 12.5hz frame rate framing works from 23 line onwards each image 1 line more tested up to 100 line but not its top limit ,showing here the bandwidth loss comes in on the higher end ...i suppose what i can output from the sound card more than likely more of a problem than the opto coupler
So every thing looks ok up to the 70s but loss sure kicks in after ,hard to get every photo right but there's enough to show the problem with trying out a higher line rate without anything that can output the correct video bandwidth to the monitor .
Below image 23 line that is the start of what it can correctly lock in frame ,i will test some more when i can, i found it will not frame 25 or 50 hz or any thing above 12.5 hz ...need more work but not impossible ...
Here its not a problem as i just need this monitor for the lower end of what it can do .
