Page 4 of 5
Posted:
Sat Jun 22, 2019 1:15 am
by smeezekitty
Oh. I don't have an easy way to test it on older versions of Windows than Windows 7. Unless I installed XP in a VM
Posted:
Sat Jun 22, 2019 8:57 pm
smeezekitty wrote:Oh. I don't have an easy way to test it on older versions of Windows than Windows 7. Unless I installed XP in a VM
i have Xp pro on my 20 yer old laplop i will give it a go and let you know .
Posted:
Sun Jun 23, 2019 9:34 am
Trying it on windows xp it loads to the point asking for a missing dll file...so almost have to see if i can add it .
Posted:
Sun Jun 23, 2019 12:47 pm
by smeezekitty
I'm not really that surprised since I built and tested everything with W7. It usually takes special consideration to support older OSes
Posted:
Sun Jun 23, 2019 7:20 pm
smeezekitty wrote:I'm not really that surprised since I built and tested everything with W7. It usually takes special consideration to support older OSes
No problems works well on windows 7 always been very happy with it ....
Posted:
Sun Jul 07, 2019 9:27 am
by smeezekitty
New version (0.4) released!
Changes:
Fixed crash when switching from video file to image file
Fixed GTK warnings/errors in console
GUI improvements
Independent RGB color gains (I had this implemented but not yet released - that's how I got color on my mechanical monitor)
Audio output device selection menu now works
Fixed several misc. bugs
Posted:
Sun Jul 07, 2019 5:56 pm
Hi it loads ok seems to run fine again ,i have to have time to look into it ,i noticed the colour menu ...
So i will have to look into how to use this ..Thanks for the work and posting any NBTV software and improvement is always welcome !
Posted:
Thu Sep 01, 2022 6:28 pm
by smeezekitty
Version 0.41 released!
This version should fix any issues with the pixbuf loader cache not being found (and warnings and GUI problems resulting therefrom)
It also makes many of the console and pop-up error and warning messages more clear. I also identified and fixed a crash that would occur somewhat randomly when changing GUI settings.
Still plenty of bugs to go and there could be new bugs introduced to feel free to test it out and let me know how this version is working. It has been about 2 years since I touched the code so it was a bit of a pain to work on.
The zip file contains both the source and a Windows installer as before (Windows 7 or newer required)
Posted:
Sun Sep 04, 2022 9:31 am
I am having a bit of trouble with this version downloads fine when i try and open my PC says it has a virus ,i tried the earlier version it downloads and installs fine this one can't get past downloading it ,just seeing it any one else is gettingthe same virus warning ?
Posted:
Sun Sep 04, 2022 11:08 am
by smeezekitty
Harry Dalek wrote:I am having a bit of trouble with this version downloads fine when i try and open my PC says it has a virus ,i tried the earlier version it downloads and installs fine this one can't get past downloading it ,just seeing it any one else is gettingthe same virus warning ?
I have no idea why. It has relatively small changes but certainly shouldn't have a virus. Probably your security software just isn't familiar with this uncommonly used program.
Posted:
Sun Sep 04, 2022 6:53 pm
smeezekitty wrote:I have no idea why. It has relatively small changes but certainly shouldn't have a virus. Probably your security software just isn't familiar with this uncommonly used program.
I tried again but instead of extracting the file i just loaded it to the HD from the compressed and that worked fine no virus warning this time ,i have yet to try this new version out but loading well so all good !
Posted:
Fri Nov 11, 2022 12:49 am
by G8EDJ
HI, downloaded this program but can't make any sense of it, there doesn't seem to be and install or .exe file?
Chris.
Posted:
Fri Nov 11, 2022 11:47 am
by smeezekitty
G8EDJ wrote:HI, downloaded this program but can't make any sense of it, there doesn't seem to be and install or .exe file?
Chris.
Chris, I cannot confirm this. It is possibly anti-malware removing the 'uncommon' and thus unfamiliar .exe file
Posted:
Fri Nov 11, 2022 7:05 pm
by Dave Moll
Apologies if this is stating the obvious, but I assume you have expanded the ZIP file, which (as stated above) contains the following:
Posted:
Wed Nov 23, 2022 6:38 pm
Dave Moll wrote:Apologies if this is stating the obvious, but I assume you have expanded the ZIP file, which (as stated above) contains the following:
In the Zip window i just select run on the exe file and let windows run it once installed you will have a few windows ,can follow my instructions on how to run it on past posts here on the early versions ..its a little tricky till you know what to do like every thing .
