harry dalek wrote:Gary did very well on he's camera in this post,well worth a look again if any one missed it .
http://www.taswegian.com/NBTV/forum/vie ... sc&start=0
harry dalek wrote:I was wondering about nbtv cameras and sync can you make a camera without it for a start ?
harry dalek wrote:Looking at this circuit for the dome sensor i was thinking the circuit could be made simpler with a LM311....looks to me like the trany one has uses a bit of feed back.
gary wrote:And this was the simple lash up used to produce the above video:
harry dalek wrote:i am wondering how bright it must be i know it must be bright enough to project but does not look like its blinding you .
harry dalek wrote:I rather your first camera system as i was thinking of making it cd sized
harry dalek wrote:Thanks fo rthe information that Gary i will have a read of the news letter for sure ,i read Klaas saying these things are harder than monitors and from what you say sounds like they do have their own touchy problems.
gary wrote:Harry, I don't have time just now for a full blurb, but I can't see how you are going to use a laser (which may be dangerous anyway) with a nipkow disk as the beam will only be picked up by one or two apertures - if you use a mirror drum that would be different.
FFS can work in daylight too, as long as the lighting is constant (i.e. DC)
TBP CAN be used without sync providing your motor speed is constant - eg a stepper or synchronous motor.
More later...
gary wrote:I see Harry, it's just that I wouldn't think under those circumstances that the laser would be bright enough - their intense brightness depends on them being collimated.
