Harry Dalek wrote:...is it going to be an all valve monitor?
It is all of my own offering, albeit some borrowed from others, both old and new...Harry Dalek wrote:Steve are you using an old circuit design or doing your own...
The heater voltage is derived from a 12V winding on a transformer with suitable dropper resistors. It's not easy to get 6.3V secondary transformers these days, and the resistance should limit the inrush current upon cold switch-on, though not one manufacturer I know of has made any reference to this extending tube life or otherwise. You can gauge the correct voltage/current quite often from the colour of the cathode. See avatar* to the right for a guide for most CRTs...Harry Dalek wrote:...I suppose care should be taken on the heater? Do you just ease the voltage up on it, which would be a normal 6.3V?
