Steve Anderson wrote:Very interesting Harry. So all that's needed is a receiver, an antenna and a PC with the appropriate software. As their life-span is limited it's probably a good idea to start considering setting up for the digital versions. I've no idea what's required for that.
By coincidence I'm also working on a receive-only satellite project. This one is for GPS. Most use GPS to find their way around in the car or record their track on a hike or similar. But I also use it as a very precise time measurement.
Steve Anderson wrote:I did some Googling yesterday trying to find out what sort of signal can be expected out of a receiver tuned to a Meteor satellite. I found lots of PC-based software but that's not what I was looking for. I didn't spend that much time on it though. I'll have another go some other time.
[/quote]As for the GPS receiver above for use with a PC running VisualGPS (for example, there are others) all that's needed is in the circuit below, you don't even need the 1PPS signal.
Steve Anderson wrote:Nice one Harry! Quite impressive.
I was wandering through the back-issues of Wireless World I have over the weekend (that's how I tripped across the JLB article I posted)
and came across a hardware-based NOAA decoder (no PC required). It seemed quite complex but sure could be simplified these days still without use of a PC. The output was onto a piece of photographic print paper wrapped around a rotating drum, then the paper had to be processed. Quite cumbersome.
A clever bod could get it to talk directly to a modern printer surely.
Viewmaster wrote:One can also download all aircraft details. height/speed/type etc etc and have a moving display
as control towers do.
One only needs a cheap UHF dongle and free software off the net.
All aircraft transmit all their details to control towers for their displays and we at home
can receive it too on 1090 MHz............all legal BTW !
Here's a shot of aircraft seen from my bedroom with just a cheap indoor 4" antenna here in
the Midlands UK. I haven't shown the plane details, just their tracks.
I even picked up one just about to cross the Channel.
Sorry it's not NBTV
Harry Dalek wrote:Have you tried it Steve in a different location just to see the difference as to its direction and range?
Users browsing this forum: No registered users and 73 guests
