Terminal board
A build to model parts for a Baird lens box, the type seen on televisors, suitable for 3D printing and use on a televisor model.
Terminal board
Postby McGee2021 » Mon Jun 19, 2017 10:49 am
I just came home from vacation earlier, and i took my 3D printer with me as an experiment in technology transportation. While there, i re designed the terminal board after i realized it was grossly over sized.
(159.05 KiB) Not downloaded yet
Fun times, ain't it?
McGee2021
Re: Terminal board
Postby Andrew Davie » Mon Jun 19, 2017 11:31 am
It looks pretty good - your printer is doing a great job of printing that isolated text. Just thought I'd suggest that if you post-drill the holes instead of printing them, you will get a more consistent "grain" and smoother top for the green baseplate area.
Re: Terminal board
Postby McGee2021 » Mon Jun 19, 2017 1:15 pm
Andrew Davie wrote:It looks pretty good - your printer is doing a great job of printing that isolated text. Just thought I'd suggest that if you post-drill the holes instead of printing them, you will get a more consistent "grain" and smoother top for the green baseplate area.
In the long run, it wont matter, since i dont predict that once this product is finished it will last more that 20 years due to the decomposition of the plastic. Also, for the knurled nuts, it seems quite difficult to find ones that match the ones that were original to the televisor, so, it means that its another part to be designed and printed. Perhaps print them, slide a nut into them, put the bolt through the board, put a washer on, and assemble it with the wires? I just sent an order for the high wattage resistors, and the 150 om variable resistor, they should be here in the next week or two, so dont plan on seeing much progress on the terminal board until they arrive. Oh Well. :cry:
McGee2021
Re: Terminal board
Postby McGee2021 » Mon Aug 14, 2017 9:38 am
I made a cord for the televisor, a replica of the original, with a fabric insulation, brass wire covers, and a bayonet plug instead of a typical plug, and lugs to connect it to the terminals.
McGee2021
Re: Terminal board
Postby McGee2021 » Mon Aug 14, 2017 9:59 am
I have also printed off supports for the terminal board, since the way I needed to print it did not let me print them already on it.
McGee2021
Return to Baird Lens Box and Face plate
